Условие подбора остекления по солнцезащитным свойствам
Conditions for selecting glazing based on sun protection properties
E. V. Korkina, Doctor of Engineering, Senior Researcher, Laboratory of Construction Lighting Engineering at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; Associate Professor, Department of Heat, Gas Supply, and Ventilation, National Research University Moscow State University of Civil Engineering Federal State Budget Educational Institution of Higher Education «Moscow State University of Civil Engineering (National Research University), MGSU
S. S. Kucherov, Postgraduate Student, Department of Heat, Gas Supply and Ventilation, MGSU
Keywords: energy conservation, sun protection coatings, solar radiation, building energy consumption, heat flow, skylight, translucent building envelopes
Translucent building envelopes are widely used in the construction of buildings for various purposes. To reduce heat loss through skylight glazing during the heating season or to prevent overheating during the cooling season, energy-saving (low-emission and sun protection) coatings are pre-applied to the glazing, which have reduced radiant heat transmittance. Glazing with low-emission coatings is selected during the heating season based on the requirement to reduce heat loss through the glazing. However, the issue of selecting solar control glazing during the cooler months to reduce the load on the air conditioning system has been insufficiently studied. This article examines the heating of indoor air from penetrating solar radiation for given characteristics of the filling of a room's light opening, including solar control glazing, and introduces a condition that these characteristics must meet to prevent indoor air overheating. Applying this condition when selecting solar control glazing will help save energy on air conditioning.
Светопрозрачные ограждающие конструкции имеют широкое применение при строительстве зданий различного назначения, при этом с целью сокращения теплопотерь через остекление светопроемов в отопительный период года или предотвращения перегрева помещений в охладительный период года на остекление предварительно наносятся энергосберегающие (низкоэмиссионные и солнцезащитные) покрытия, которые имеют пониженное пропускание лучистой теплоты. Подбор остекления с низкоэмиссионными покрытиями в отопительный период года проводится на основе условия сокращения теплопотерь через него. Однако недостаточно изучен вопрос подбора солнцезащитного остекления в охладительный период года с целью снижения нагрузки на систему кондиционирования воздуха. В статье рассматривается нагрев воздуха в помещении от проникающей солнечной радиации при заданных характеристиках заполнения светопроема помещения, включающего солнцезащитное остекление, и вводится условие, которому должны отвечать эти характеристики для предотвращения перегрева воздуха в помещении. Применение полученного условия при подборе солнцезащитного остекления будет способствовать сбережению энергии на кондиционирование воздуха в помещении.
Статья опубликована в журнале “АВОК” за №3'2026
- Системы автоматизации и безопасность здания. Аспекты использования системы автоматизации для обеспечения технологической безопасности зданий
АВОК №8'2006 - «Стеклянный дом» с пассивным использованием тепла солнечной радиации
АВОК №5'2003 - Влияние декоративных решеток на тепловую мощность внутрипольных конвекторов
АВОК №8'2024 - Возможности реализации механизма энергосервиса на промышленных предприятиях
Энергосбережение №2'2019 - Энергоэффективные решения в практике проектирования операционных: опыт Нидерландов
АВОК №8'2019 - Повышение энергоэффективности и эксплуатационной надежности систем обеспечения параметров микроклимата животноводческих зданий и сооружений
АВОК №6'2022 - О новых приоритетах и элементах энергосистем для городов будущего
Энергосбережение №6'2025 - Модернизация существующих зданий: теплоэффективность через энергосервисный контракт
Энергосбережение №5'2026 - Теплотехнические характеристики ограждающих конструкций зданий. Ч. 1. Европейский подход и метод расчета
Энергосбережение №7'2017 - Энерго- и ресурсосбережение в агропромышленном комплексе. Взгляд архитектора
