Математическая модель оценки требуемых объемов реконструкции тепловых сетей
Mathematical Model for Assessing the Required Scope of Heat Network Reconstruction
D. A. Milkov, Head of the Heat Supply System Development Department, Gazprom Promgaz JSC
A. V. Mukhambaev, Chief Specialist, Heat Supply System Development Department, Gazprom Promgaz JSC
A. S. Dergovitsa, Head of the Energy Source Development Sector, Gazprom Promgaz JSC
A. S. Gorshkov, Doctor of Technical Sciences, Head of the Department for the Development of Energy Supply System Schemes and Development Programs, Gazprom Promgaz JSC
Keywords: district heating, heat supply scheme, heat networks, pipelines, service life, physical deterioration, reconstruction
The article presents a comprehensive assessment of the impact of heat network reconstruction and new construction volumes on the weighted average operating period of pipelines in district heating systems. An equation is derived for calculating the weighted average operating period of pipelines, taking into account the scope of heat network reconstruction and new construction. A qualitative analysis of the resulting equation is performed, making it possible to predict the weighted average operating period of heat network pipelines depending on the volume of pipeline replacement. The research results can be applied in the development of district heating schemes and development programs to substantiate the required scope of heat network reconstruction.
В статье приведена комплексная оценка влияния объемов реконструкции и нового строительства тепловых сетей на средневзвешенный период эксплуатации трубопроводов систем централизованного теплоснабжения. Получено уравнение для расчета средневзвешенного периода эксплуатации трубопроводов с учетом объемов реконструкции и нового строительства тепловых сетей.Выполнен качественный анализ полученного уравнения, позволяющий прогнозировать средневзвешенный период эксплуатации трубопроводов тепловой сети в зависимости от объемов перекладки. Результаты исследования могут применяться при разработке схем и программ развития систем централизованного теплоснабжения для обоснования объемов реконструкции тепловых сетей.
Статья опубликована в журнале “АВОК” за №6'2026
- Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №4'2019 - Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №5'2019 - Что ждет Россию в будущем – котельные в каждом доме или все-таки централизованное теплоснабжение на базе теплофикации?
АВОК №2'2008 - Тепловая изоляция трубопроводов тепловых сетей
Энергосбережение №5'2002 - Тепловые сети систем централизованного теплоснабжения
Энергосбережение №5'2004 - Эффективная энергетическая характеристика температурного поля подземного теплопровода для сравнения материалов мониторингового обследования методом тепловой аэросъемки
Энергосбережение №1'2026 - «РОСТерм black»: высокие стандарты качества
АВОК №7'2017 - Мониторинг внедрения низкоуглеродных технологий в зданиях
Энергосбережение №4'2020 - Прогнозирование отказов тепловых сетей с учетом температуры теплоносителя и срока службы теплопроводов
АВОК №4'2026 - Дешевый хомут – дорогая ошибка, или почему крепеж не «расходка»
АВОК №7'2026
