Прогнозирование отказов тепловых сетей с учетом температуры теплоносителя и срока службы теплопроводов
Failure Prediction for Heat Networks Considering Heat Carrier Temperature and Pipeline Service Life
R. Yu. Rozhkov, Candidate of Engineering, Deputy Chief Engineer of Teploset Saint Petersburg
V. V. Khotyakov, Chief Specialist at the Research and Technical Center “Integrated Development of Engineering Infrastructure” in Saint Petersburg, Gazprom Promgaz
S. N. Kiryukhin, Candidate of Engineering, Associate Professor, Leading Specialist at Nevskaya Energetika
Yu. V. Yuferev, Doctor of Engineering, Professor, Project Manager at the Research and Technical Center “Integrated Development of Engineering Infrastructure” in Saint Petersburg, Gazprom Promgaz
Keywords: heat energy source, district heating system, heat networks, heat supply regulation, temperature schedule, maximum-temperature testing, failure rate, specific damage rate, heat supply organizations, combined heat and power plant, heating season
In recent years, considerable attention has been paid to heat supply regulation – temperature schedules – in district heating systems. The main argument for limiting the temperature in supply mains is the high accident rate of heat networks. Therefore, making a well-grounded decision on the selection of an optimal temperature schedule is impossible without taking into account the depletion of pipeline service life and the influence of heat carrier temperature on the failure rate of heat network operation.
The article presents a mathematical relationship describing the failure rate of heat networks as a function of two factors simultaneously: the duration of heat network operation and the temperature of the transported heat carrier.
В последние годы значительное внимание уделяется регулированию теплоотпуска (температурным графикам) в системах теплоснабжения. Основным аргументом ограничения температуры в подающих магистралях указывается высокая аварийность тепловых сетей (ТС). Поэтому принятие обоснованного решения по выбору оптимального температурного графика невозможно без учета выработки эксплуатационных ресурсов теплопроводов и влияния температуры теплоносителя на интенсивность отказов в работе ТС.
В статье представлена математическая зависимость интенсивности отказов ТС одновременно от двух факторов: продолжительности эксплуатации тепловых сетей и температуры транспортируемого теплоносителя.
Проблема возврата к проектным температурным графикам регулирования в существующих системах централизованного теплоснабжения (СЦТ) широко обсуждается на научных конференциях и в публикациях. Основным аргументом ограничения температуры в подающих магистралях указывается высокая аварийность тепловых сетей (ТС). Поэтому принятие обоснованного решения по выбору оптимального температурного графика (ОТГ) невозможно без учета выработки эксплуатационных ресурсов теплопроводов и влияния температуры теплоносителя на интенсивность отказов в работе ТС.
Данная публикация дополняет ранее выполненные авторами исследования, в которых на основании статистического анализа отказов в работе ТС одной из крупнейших теплоснабжающих организаций Санкт-Петербурга была разработана математическая зависимость интенсивности отказов ТС от продолжительности их эксплуатации, типа прокладки и диаметра трубопроводов. В настоящей работе сделан следующий шаг: получена математическая зависимость интенсивности отказов ТС одновременно от двух факторов: продолжительности эксплуатации тепловых сетей и температуры транспортируемого теплоносителя.
Введение
Режимы регулирования теплоотпуска в системе централизованного теплоснабжения (СЦТ) определяются на этапе ее проектирования и предполагают соответствие выработки и распределения требуемого потребителям количества теплоты в зависимости от температуры наружного воздуха. В крупных СЦТ Санкт-Петербурга регулирование отпуска тепла потребителям осуществляется «качественным» способом, т. е. путем изменения температуры теплоносителя при постоянном расходе. При этом проектным температурным графиком является график 150/70 °С.
В публикации [1] сделан вывод о возможности перехода на «оптимальный» температурный график при обязательности выполнения условия «минимизации конечных тарифов на тепловую энергию» и технико-экономическом обосновании такого графика «для каждой системы теплоснабжения».
В другой публикации [2] проанализированы возможности снижения (относительно проектных) температурных графиков СЦТ на базе ТЭЦ с целью увеличения эксплуатационных ресурсов теплопроводов существующих тепловых сетей с одновременным повышением доли комбинированной выработки электрической энергии на ТЭЦ.
При этом большинство исследователей согласны с утверждением, что температура транспортируемого теплоносителя является одним из важных факторов, влияющих на интенсивность отказов в работе тепловых сетей (ТС).
Анализ приведенных выше публикаций и выполненных в последнее время по этой теме исследований подтверждает ее актуальность.
Поставленная в настоящем исследовании задача решалась на основе статистического анализа эксплуатационных данных с построением (выбором) математической модели прогнозирования интенсивности отказов ТС по температуре теплоносителя и продолжительности эксплуатации теплопроводов, при этом принято, что зависимость интенсивности отказов ТС от продолжительности их эксплуатации достоверно описывается распределением Вейбулла–Гнеденко [3] с использованием методов линейного и целочисленного программирования [4, 5], а также байесовских методов [6].
Результаты исследований
В публикации [3] приведена установленная по результатам статистического анализа данных об отказах ТС зависимость интенсивности отказов теплопроводов от продолжительности их эксплуатации:
где:
ξmax – максимальное значение интенсивности отказов теплопроводов анализируемой группы однотипных (по типу прокладки и диаметру) участков ТС, ед./(км · сутки);
τ - фактическая продолжительность эксплуатации, год;
γ - показатель, характеризующий реальный эксплуатационный ресурс теплопроводов анализируемой группы однотипных участков ТС, год;
λ - показатель (коэффициент масштаба), характеризующий темп изменения интенсивности отказов теплопроводов анализируемой группы однотипных участков ТС (λ = 4).
В публикации [7] представлен алгоритм использования зависимости (1) для прогнозирования отказов ТС в одной крупной ТСО Санкт-Петербурга при различных вариантах объемов (и темпов) реконструкции ТС.
Следующим этапом развития модели интенсивности отказов стал поиск зависимости ее параметров от температуры теплоносителя в ТС.
Основное допущение, положенное в основу разработки модели расчета интенсивности отказов, состоит в том, что зависимость от температуры в формуле (1) реализует параметр ξmax и эта зависимость имеет следующий вид:
где:
T - температура теплоносителя в подающем теплопроводе, °С;
T0 = 70 – минимальная температура теплоносителя в подающем теплопроводе (температура нижней срезки температурного графика), °С;
α, β, ξ0, δ – параметры модели, значения которых определяются по результатам статистического анализа фактических данных об отказах ТС, зарегистрированных в т. ч. и при проведении испытаний тепловых сетей на максимальную температуру.
Статистическому анализу подвергнуты данные по конкретной СЦТ одной из самых больших по мощности ТЭЦ Санкт-Петербурга, полученные в отопительные периоды (ОП) 2021–2025 годов, в период с января по февраль 2026 года, а также в периоды проведения испытаний на максимальную температуру: Tmax = 110 °C (2016 год) и Tmax = 100 °C (2021 год).
Расчет параметров α, β, ξ0, δ выполнялся решением задачи по поиску функции вида (3), обеспечивающей минимальное отклонение расчетного числа отказов ТС за каждый базовый период от соответствующих фактических значений.
Для построения расчетного алгоритма все ТС в системе теплоснабжения ТЭЦ были разбиты на группы участков, различающиеся продолжительностью эксплуатации.
Объединением формул (1) и (2) было получено следующее выражение для расчета усредненной по исследуемой системе теплоснабжения интенсивности отказов, если температура транспортируемого теплоносителя поддерживалась равной T:
где:
j - условный порядковый номер исследуемого базового периода;
Aj – параметр, укрупненно характеризующий выработку эксплуатационных ресурсов теплопроводов СЦТ в j-й базовый период, равный средневзвешенному по протяженностям всех участков отношению интенсивности отказов, рассчитанной исходя из фактической продолжительности их эксплуатации, к максимальному значению, который рассчитывается по формуле:
где:
Lji - суммарная длина трубопроводов (в однотрубном исчислении) i-й продолжительности эксплуатации в j-м базовом периоде, км.
Определение параметров зависимости (3) выполнено в два этапа. На первом этапе по методике [3] были определены γ и ξ’max (без учета влияния температуры теплоносителя), значения которых равны: γ = 22,06 лет и ξ’max = 0,00467 ед./(км · сутки). Значение ξ’max при этом использовалось как начальное приближение для ξ0 в зависимости (2).
На втором этапе были рассчитаны параметры α, β, ξ0, δ по критерию минимального отклонения результатов расчета от фактических данных, что обеспечивается минимизацией следующего функционала:
где:
ξрасчет j – расчетное значение усредненной (в исследуемой СЦТ) интенсивности отказов ТС за j-й базовый период, ед./(км · сутки);
ξфакт j – среднее (за j-й базовый период) значение фактической интенсивности отказов ТС, ед./(км · сутки):
где
Nфакт j - количество отказов теплопроводов, фактически зарегистрированных в j-м базовом периоде эксплуатации, ед.;
Dj - продолжительность j-го периода эксплуатации ТС, сутки;
LΣj - суммарная длина (в однотрубном исчислении) теплопроводов ТС в j-й период эксплуатации, км.
Исходные данные и результаты расчетов ξфакт j приведены в табл. 1.
С целью получения расчетной зависимости для ξрасчет j каждый базовый период был разделен по длительности на интервалы, характеризующиеся тем, что в течение входящих в этот интервал суток среднесуточная температура сетевой воды изменялась в достаточно узком заданном диапазоне. Принятое разбиение базовых периодов на интервалы представлено в табл. 2.
С использованием формул (1) и (2) было получено расчетное выражение для ξрасчет j:
где:
k - условный порядковый номер интервала продолжительности базового периода с относительно постоянной температурой теплоносителя (k ∈ 1, …, 5);
Tфjk - фактическая температура теплоносителя, усредненная за k-й интервал j-го базового периода;
Mjk - фактическое число дней входящих в k-й интервал j-го базового периода;
Mj - суммарная продолжительность j-го базового периода (в сутках), которая равна
После подстановки расчетных формул для ξфакт j и ξрасчет j в формулу (5) задача поиска минимума функционала ψ сводилась к решению системы нелинейных уравнений, которая формировалась путем приравнивания нулю частных производных минимизируемой функции по искомым параметрам. Полученная система уравнений решалась численным методом с использованием языка программирования Python.
Таким образом, были определены следующие значения параметров модели (3): α = 0,0484 ед./(км · сут.); β = 38,879 °С; ξ0 = 0,00413 ед./(км · сут.); δ = 12.
Результаты прогнозирования интенсивности отказов теплопроводов в зависимости от температуры теплоносителя, полученные с использованием разработанной модели, приведены на рисунке. Эти результаты следует учитывать для прогнозирования повреждаемости ТС при выборе температурного графика регулирования теплоотпуска от источника тепловой энергии.
Точность прогнозирования интенсивности отказов с помощью разработанной модели в заданных (исходных) диапазонах изменения температуры теплоносителя и продолжительностей эксплуатации теплопроводов в среднем составляет 3,5 %, что соответствует предварительно предъявляемым к математической модели требованиям.
Выводы
Выполненный обзор публикаций по теме исследования показал, что есть авторы, поддерживающие необходимость возврата к проектным температурным графикам регулирования в существующих крупных СЦТ, но также имеются публикации, в которых говорится о необходимости изменения проектного температурного графика 150/70 °С в сторону его понижения либо введения в график ограничения максимальной температуры с целью предотвращения отказов ТС в ОП и неблагоприятных социальных последствий возможных инцидентов.
На основании статистического анализа данных об отказах ТС одной из крупных ТСО Санкт-Петербурга определены параметры расчетной зависимости интенсивности отказов ТС одновременно от двух параметров: температуры теплоносителя и продолжительности эксплуатации теплопроводов.
Проведенный предварительный анализ достоверности разработанной математической модели требует уточнения по результатам планируемых испытаний ТС на максимальную температуру в зоне теплоснабжения исследуемой ТЭЦ и получения новых статистических данных. В этой связи разработанная модель прогнозирования интенсивности отказов ТС (в зависимости от температуры теплоносителя и продолжительности эксплуатации теплопроводов) требует более глубокой проверки эффективности ее применения и соответствующей доработки путем последовательного исключения принятых при ее разработке допущений.
Результаты исследования могут быть использованы при разработке и актуализации схем теплоснабжения, в частности при выполнении технико-экономического обоснования выбора оптимального температурного графика регулирования, а также при формировании инвестиционных программ ТСО.
1. Миргородский А. И. Оптимальный температурный график // Teplovichok. Тепло и ЖКХ. – 13.05.2025.
2. Папушкин В. Н., Желнов А. Ю., Щербаков А. П. Пересмотр температурных графиков с использованием модели предиктивного анализа работы оборудования в тепловой сети // Электрические станции. – 2022. – № 4. – С. 9–13.
3. Рожков Р. Ю., Хотяков В. В. Расчетная модель прогнозирования интенсивности отказов участков тепловых сетей на примере системы теплоснабжения АО «Теплосеть Санкт-Петербурга» // Инженерные системы. – 2025. – № 4. – С. 34–40.
4. Заботин И. Я., Заботин Я. И. Методы и вычислительные приемы в линейном программировании. – Казань: Изд-во Казан. ун-та, 2014.
5. Колоколов А. А., Девятирикова М. В. Задачи и алгоритмы целочисленного программирования: анализ устойчивости: монография. – Омск: ОмГУ, 2015.
6. Прокопчина С. В. Байесовские интеллектуальные технологии в задачах моделирования закона распределения в условиях неопределенности. Монография. – М.: ИД «Научная библиотека», 2020.
7. Рожков Р. Ю., Юферев Ю. В. Прогноз динамики изменения повреждаемости тепловых сетей ТСО при различных сценариях их реконструкции // Инженерные системы. – 2026. – № 1. – С. 42–46.
Статья опубликована в журнале “АВОК” за №4'2026
- Планирование объемов реконструкции тепловых сетей по целевому уровню отказов на примере крупной ТСО
АВОК №5'2026 - Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №4'2019 - Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №5'2019 - Что ждет Россию в будущем – котельные в каждом доме или все-таки централизованное теплоснабжение на базе теплофикации?
АВОК №2'2008 - Новое поколение тепловых сетей – высокоэффективные системы трубопроводов с пенополиуретановой изоляцией
Сантехника №5'2004 - Возрождение теплофикации новые подходы
АВОК №7'2008 - Анализ фактических тепловых параметров зданий жилого фонда Москвы в условиях реальной эксплуатации
Энергосбережение №7'2024 - Опыт диспетчеризации тепловой сети ОАО «ИжАвто»
Энергосбережение №4'2007 - Вопросы отопления. Мнения экспертов
АВОК №4'2011 - Влияние индивидуального регулирования отопления на экономию тепловой энергии: проблема межквартирных перетоков
АВОК №6'2026
