(495) 984-99-72 ""
(495) 621-80-48 (./) "-"
(495) 107-91-50
Technical literature""
Air conditioning. Part 1
Year of publication: May 2015
Authors: M. Tarabanov
The book "Air conditioning" consists of two heads: "Basic provisions of thermodynamics of damp air" and "Air conditioning system". In chapter 1 main attention is paid to i-d to the chart of damp air: her knowledge and ability to work with it are obligatory requirements for any expert in the field of air conditioning; differences between i-d and h-d charts are considered. In chapter 2 classification of air conditioning systems is given and almost all known systems are considered, the examples of their calculation followed from the realized projects are given.
Smoking areas. Design of ventilation systems
Year of publication: May 2014
Authors: M. Brodach / A. Naumov / A Pershin / B. Bronsema
In the book "Zones for smoking. Design of system of ventilation" such questions as structure of a tobacco smoke and ways of measurement of its concentration indoors are considered; Russian and foreign standards; methods of an assessment of quality of air; ways of the organization of air exchange; types of zoning of rooms; organization of a microclimate; the installations of system of ventilation located outside the room; use of air cleaners; filtration methods. The certain head is devoted to smoking cabins.
Chilled Beams: Design, Installation and Maintenance
Year of publication: May 2012
Authors: M. Brodatch, M. Virta, V. Ustinov
Chilled beam cooling is relatively new technology that has rapidly spread all over the Europe. Its advantages are in low noise generation, low room velocities and flexibility. High temperature level of cooling media also improves the energy efficiency of the mechanical cooling and allows longer periods of free cooling.
Water supply and water disposal of public buildings
Year of publication: May 2011
Author: A. Otstavnov
In the book "Water Supply and Water Disposal of Public Buildings" long-term experience of scientific researches and design of systems of water supply and water disposal of public buildings is generalized, their current state and prospects of the structure of power effective and resource-saving systems is considered.
Systems of water heating of multystoried buildings. Technical recommendations about design
Year of publication: May 2010
Author: V. N. Karpov
Book "Systems of water heating of multystoried buildings. Technical recommendations about design" is the alphabet of design of systems of water heating. In it the main systems of heating are comprehensively lit: the vertical one-pipe and two-pipe, horizontal apartment. Their merits and demerits, scopes are considered. The special attention is paid to a question of hydraulic balance of systems of heating. Certain heads are devoted to the subjects most urgent today economy of thermal energy in systems of heating and ways of the apartment accounting of an expense of warmth on heating. Detailed characteristics are given to different types of heating devices.
Polypropylene pressure head pipelines in engineering systems of buildings
Author: V. E. Bukhin
In the book "Polypropylene Pressure Head Pipelines in Engineering Systems of Buildings" for the first time in domestic practice data on properties of pipes are generalized from polypropylene, standard and methodical base of use of pressure head pipelines in sanitary and technological systems, a range of pipes and connecting details, about types and ways of connection of pipes.
Ventilating equipment. Technical recommendations for designers and assemblers
Year of publication: May 2009
Author: V. G. Karadzhi / Yu. G. Moskovko
Book "Ventilating equipment. Technical recommendations for designers and assemblers" is the guide to the modern ventilating equipment.
In the book topical issues of effective use of the ventilating equipment are formulated, general information about fans, the main information on aerodynamics and thermodynamics is given. Features of operation of fans in networks, vozdukhopritochny installations, water heating units, acoustic characteristics of fans are considered.
Protection against noise and vibrations in systems of OVK. Practical guidance
Author: Mark Schaffer (Mark E. Schaffer)
The book "Protection against noise and vibrations in systems of OVK. Practical guidance" it is devoted to the acoustic and vibration problems arising at design of systems of OVK. In the book "Protection against noise and vibrations in systems of OVK. Practical guidance" are covered not only theoretical basics of acoustics and vibrations, but also practical sides of the application of this knowledge in real situations of ventilating systems are in detail lit.
Treatment-and-prophylactic establishments. General requirements to design of systems of heating, ventilation and air conditioning
Year of publication: May 2008
Author: A. P. Borisoglebskaya
In the book "Treatment-and-prophylactic establishments. The general requirements to design of systems of heating, ventilation and air conditioning" contain recommendations about design of systems of heating, ventilation and air conditioning, the organization of rational air exchange in rooms, to ways of management and operation of systems of treatment-and-prophylactic establishments. Synthesis of requirements of the existing standards in a uniform source is the basis for the book.
Aerodynamics of ventilation
Author: V. N. Posokhin
The book "Aerodynamics of Ventilation" is devoted to aerodynamic aspects of calculation of elements and systems of ventilation. Laws of formation of stitched and thermal streams, currents near the soaking-up openings, the movements of air masses in the ventilated rooms are considered.
Autonomous systems of the sewerage. Theory and practice
Year of publication: May 2007
Author: A. A. Ratnikov
Book "Autonomous systems of the sewerage. The theory and practice" contains theoretical bases of biological cleaning of household drains, the description of the constructions used for construction of the independent sewerage of separate country houses and a practical advice on construction of autonomous systems of the sewerage. The book is written in simple and clear language.
Heat losses inside buildings
Author: E.G. Malyavina
The book gives a detailed overview of all stages involved in calculation of heat losses for a modern building, based on the modern methodological and regulatory guidelines.
The book gives values for specific thermal characteristics of modern residential and public buildings, recommendations on registration of heat gains inside from solar radiation in calculation of the buildings heat consumption during the heating period.
Each section contains examples of calculations.
Engineering equipment for high-rise building (in Russain)
Year of publication: 2007
This book provides the first summary of Russian experience in design and operation of high-rise buildings.
The first chapter describes global experience in design of engineering equipment for the most famous high-rise buildings. Subsequent chapters discuss parameters of external atmosphere, heating, ventilation and air conditioning, fire protection, water supply and drainage, garbage removal, clothes supply, automation systems implemented on specific objects. These chapters give calculation of air rate for a multistorey residential building during the year, methods for calculation of required ventilators' parameters for smoke protection system, calculation of sewage system, as well as the concept for evaluation of investing efficiency into heat energy supply and energy conservation in buildings and the method for determination of local aerodynamic effects on a high-rise building.
Copper pipes in technical systems of buildings
Author: G.S. Vlasov
For the first time in the national publishing history, one book collects fragmented information about properties of copper and its alloys, regulatory base for using of pipes in plumbing and gas supply systems, about classification of pipes and fittings, about types and methods of pipe junctions. This book is useful for designers, because it covers design and calculation of pipe systems for cold and hot water supply, water-based heating and heated floors, gas supply.
Displacement ventilation in non-industrial premises
Year of publication: 2006
This guidebook is aimed at practicing consulting and contracting engineers. It provides a comprehensive and easy-to-understand design manual that takes into account the experiences gained in practical applications and research, and answers the questions:
What are the benefits of displacement ventilation in commercial premises? What are the limitations? Where should displacement ventilation be applied, and where should it be avoided?
It also deals the latest development in displacement techniques, other than floor-mounted supply units. Design examples are given for the most common types of application.
Thermal physics in construction of buildings envelopes
Author: K.F. Fokin
Publication of new edition of the book by K.F. Fokin Thermal physics in construction of buildings envelopes the book that has, along with numerous other works, brought the author world fame.
The book contains detailed description of thermal technical properties of construction materials, heat transfer for stationary thermal flows, calculation of flat and spatial thermal fields, air penetration through envelopes, peculiarities of thermo-technical mode of individual parts of envelopes, behavior of envelopes after application of liquid and vaporized moisture.
Guide on evaluation of economic performance of investments into energy-saving activities
Authors: A.N. Dmitriyev, I.N. Kovalev, Yu.A. Tabunschikov, N.V. Shilkin
Year of publication: 2005
Construction of energy efficient buildings and implementation of energy-saving technologies require application of long-term investments. The book Guide on evaluation of economic performance of investments into energy-saving activities is meant to help the investors make a justifies choice between portfolio investments, investments into other areas and investments into energy-saving technologies. This book is addressed to investors, design engineers, builders, manufacturers of technical equipment for buildings, power engineers, and teachers and students of engineering, construction and energy schools.
Ventilation of multistory residential buildings
Authors ProfessorI.F. Levchak and Candidate of technical Sciences A.L. Naumov
This books focuses on air exchange in multistory residential buildings with consideration of all factors affecting it: difference between inside and outside air temperatures, wind velocity and direction, specifics of ventilation devices, as well as layout and construction of a building.
Industrial excreta into atmosphere. Engineering calculations and inventory making (in Russain)
Author: Kvashnin I. M.
This book provides an attempt to systemize different computational methods of throwing out the atmosphere pollutions. The most frequently used information is reduced to four computational methods accounting for characteristics of equipment, specific pollution excreta per unit of used material, given intensity of surface evaporation, balance of pollutions contained in materials and excreting pollutions.
The author describes 62 detailed examples of computations of excreta and pollution throw-out during mechanical metal and timber manufacturing, welding, varnish and paintcovering, thermal metal processing, linear production, plastic goods production, galvanic covering, radioelectronic production, from disorganized sources and parkings and autoservice workshops.
The value of this issue consists in 54 supplements which contain the whole reference and normative material and necessary initial information about polluting throw-out computations.
HVAC Design Guide for Tall Commercial Buildings (in Russain)
Author: Donald E. Ross
Year of publication: 2004
The content of this book results from the design experience of one practitioner but has been influenced by useful suggestions during its preparation from a number of sources. It has been prepared as a research project authorized by ASHRAE.
Energy - Efficient Building
Authors: Tabunshchikov Yu. A., Brodach M. M., Shilkin N. V.
Year of publication: 2003
Descriptions are given of the best-known energy-efficient buildings constructed in the world since 1972: residential, public high-rise, sports, educational, and hospital types, as well as an urban settlement. Energy-efficient architectural, engineering and technological solutions are reviewed, as well as the scientific design basis of energy-efficient buildings.
The book is intended for a wide range of experts including architects, engineers, research engineers, designers, teachers and students of higher or secondary educational institutions, investors, builders, and operators.
Mathematical Models of Thermal Conditions in Buildings
Authors: Yuri A. Tabunschikov, Marianna M. Brodatch
Year of publication: 2001
This new book is dedicated to the theory and practice of a mathematical modeling method for studying the thermal behavior of the rooms and buildings. The peculiarity of the material discussed is that it contains fundamental concepts of the theory of thermal behaviour mathematical modeling as well as the applications of the method of mathematical modeling in solving urgent practical problems.
New English-Russian, Russian-English Dictionary of Technical Terms and Phrases of Heating, Ventilation, Refrigeration, Air-Conditioning, Heat Supply and Building Thermophysics
Year of publication: 2009
The dictionary is composed of two parts: English to Russian and Russian to English, and Appendices. Appendices contain reference materials: technical abbreviations; short and full names of various international associations and organizations; units of measurement; SI prefixes; main physical constants; units allowed for use equally with the SI units and off-system units; non-metric units used in USA and Great Britain; similarity criteria.
English-Russian, Russian-English dictionary of water supply, waste water and water protection
For the first time all the major terms related to water supply, waste water and water protection are collected in one dictionary. Not only dictionaries, but also various regulatory documents were used as sources. Such approach facilitates creation of the unified termbase and allows for providing the most complete and precise information
"Building Automation and Control Systems" Terms and Definitions
English - German - Russian Dictionary
English-German-Russian terms dictionary is the part of ABOK standards set and include translation of terms and definitions the most often used in ISO standards 16484 "Building Automation and Control Systems", which are developed by ISO (ISO, http://www.iso.org) experts and CEN (http://www.cenorm.be) experts. ABOK committee "Intelligent Buildings" has been developing the set of national standards for Building Automation and Control Systems (BACS). This set of standards will establish common understanding and specification of BACS functionalities. In 2002 ABOK specialists began to represent Russian Federation in ISO TC 205 work by the approval of Gosstroy.
ASHRAE , , (-)
: 2002
- - , , , , 12 000 , 2001 "".
English-Russian and Russian-English HVAC dictionary
This dictionary is the most fully compiled in its field. It contains over 12 000 technical terms, alphabetically arranged.
The dictionary is designed expressly for widest possible variety of users; it will be of interest and value to manufactures, contractors and consulting engineers, scientists, students home and office libraries.
With this in mind, it was evident from the beginning that the dictionary must be highly selective. The terms included are all officially recognized and in common use within the heating, ventilation, refrigeration and air-conditioning field. The panel compiling the dictionary is all professional engineers.
Rambler's Top100 Rambler's Top100
